AMORTYZATOR I ROZPÓRKA, ZESP., PRZEDNI, PRAWY(-A, -E), Z OKABLOWANIEM (IDENT BY) (DLA IDS+) (JNS - STOSOWAĆ 93196684 ----3 44 706) (NR PRODUKCYJNY 13199459)
Kod OEM: 344396
AMORTYZATOR I ROZPÓRKA, ZESP., PRZEDNI, LEWY(-A, -E), Z OKABLOWANIEM (IDENT AY) (DLA IDS+) (JNS - STOSOWAĆ 93196683---- 3 44 705) (NR PRODUKCYJNY 13199458)
Kod OEM: 344395
SACHS 312 016 prawy
SACHS 312 015 Lewy
TYŁ
AMORTYZATOR, ZESP., Z CZĘŚCIAMI MONTAŻOWYMI, PRAWY(-A, -E) (IDENT F4) (NR PRODUKCYJNY 13198718)
Kod OEM: 436351
6
AMORTYZATOR, ZESP., Z CZĘŚCIAMI MONTAŻOWYMI, LEWY(-A, -E) (IDENT F3) (NR PRODUKCYJNY 13198717)
Kod OEM: 436350
SACHS 312 022
SACHS 312 021
ZESTAW, NAPRAWCZY, CIĘGNO, WEWNĘTRZNY(-A, -E) (NR PRODUKCYJNY 13266155) Kod OEM: 1603642
1603287; 1603303; 1603642; 93186330; 93189451; 93191521
MOOG OP-AX-4162
FEBI BILSTEIN 34298
RTS 92.90398+
LEMFÖRDER 27726 01
DLA KÓŁ 18 CALOWYCH
ZESTAW, NAPRAWCZY, CIĘGNO, WEWNĘTRZNY(-A, -E) (DLA KÓŁ 18 CALOWYCH ZAMONTOWANYCH FABRYCZNIE) (JNS - STOSOWAĆ 93189670 16 03 359) (NR PRODUKCYJNY 13182644)
Kod OEM: 1603268
Półosie LÖBRO 305203
WAŁ, ZESP., NAPĘD, PRAWY(-A, -E) (IDENT XB) (BEZ NADAJNIKA)
Kod OEM: 374812
SKF 8275 VKJC----LÖBRO 305203
PRZEGUB WAŁU, ZESP., ZEWNĘTRZNY, Z ZESTAWEM OSŁON
Kod OEM: 1603275
GSP 817051-------SKF VKJA 3120---------JPN 10P9054-JPN---METELLI 15-1506MET---MEYLE 6144980030---MAGNETI MARELLI TOJ0104----
LÖBRO 304383-----DENCKERMANN C120038----TOPRAN 207 193
Kod OEM: 1603268
Kod OEM: 344396
Kod OEM: 344395
SACHS 312 016 prawy
SACHS 312 015 Lewy
TYŁ
Kod OEM: 436351
6
Kod OEM: 436350
SACHS 312 022
SACHS 312 021
MOOG OP-AX-4162
FEBI BILSTEIN 34298
RTS 92.90398+
LEMFÖRDER 27726 01
DLA KÓŁ 18 CALOWYCH
Kod OEM: 1603268
Kod OEM: 374812
Kod OEM: 1603275
Kod OEM: 1603268
ROZRUSZNIK, ZESP. (CZĘŚĆ ZAMIENNA 93175892 / 62 02 057 OPEL)
Kod OEM: 6202066
AS-PL S0098- 293,00 zł
CASCO CST10200AS 305,00 zł
HELLA 8EA 012 526-831 535,00 zł
VALEO 438131 769,00 zł
VALEO VAL458184 589,00 zł
MAGNETI MARELLI MSRC879 376,00 zł
MAGNETI MARELLI MRS17920 431,00 zł
VEMO V40-12-17920 477,00 zł
EST-1006 521,00 zł
AS-PL S1101 (DELCO)/ASP 563,00 zł
AS-PL S1101(DELCO) 524,00 zł
Kod OEM: 6202066
EST-1006 521,00 zł
Przecież to Prawa/Lewa strona zabudowy .
